hamfiles
I'm building a regulated power supply, and I'm trying to save money by not buying a transformer. I got to thinking, why not simply divide the voltage. My mains outlet is 120 Vac. I want 60 volts dc output to a high voltage regulator. With 2 2.4 k resistors, the current draw should only be 25 milliamps. And when I tap into this, won't the circuit only see one resistor as Ri, and be able to draw as much current as needed (minus the 25 millilamp drop)?
Are there any drawbacks to using a voltage divider this way? I would not actually use two 400 watt resistors, I would use several smaller ones in parallel to get equivalent values in circuit, whatever combo is cheapest. Maybe some 50 watt ones. Thanks in advance for any info.
