USB Techno...n Flash Drives
This site has some good information:
USB 1.0, USB 2.0, USB 3.0 : Guide
From that site:
What is USB 1.0?
It is basically the first standard definition of USB it supports a low speed rate of 1.5 Mbit/s. It is intended primarily to save cost in low-bandwidth human interface devices (HID) such as keyboards, mice, and joysticks.
What is USB 1.1?
It is the next generation of the USB Devices. It supports full speed rate of 12 Mbit/s. It is very similar to the previous standard except each bit transfer is 8 times faster. All USB hubs support full speed.
What is USB 2.0?
A hi-speed (USB 2.0) rate of 480 Mbit/s was introduced in 2001. All hi-speed devices are capable of falling back to full-speed operation if necessary; they are backward compatible. Connectors are identical to the original USB.
What is USB 3.0?
It boasts a much more higher data transfer bandwidth of SuperSpeed (USB 3.0) rate at 5.0 Gbit/s. The USB 3.0 specification was released by Intel and partners in August 2008. New devices supporting USB 3.0 is expected to be produced by the end of this year. The new connectors will be backward compatible but they will include a new wiring system to allow for full duplex communication.
You can probably buy 1 TB flash drives, for 4-10k
Do you have any idea of the data density level even the highest capacity chips are doing now, the bit density is nearly an order of magnitude higher than blueray. Let alone the complexity of putting them into mechanical arrays which allow larger sizes possible. This can't be done 'on die' It's like trying to build the entire dynamic earth one atom at a time.
What is USB 1.0?
>What is USB 1.1?
.....speed rate of 12 Mbit/s. It is very similar to the previous standard except each bit transfer is 8 times faster..... ((All USB hubs support full speed?))
>What is USB 2.0?
.........hi-speed (USB 2.0) rate of 480 Mbit/s.......
>What is USB 3.0?
......data transfer bandwidth of SuperSpeed (USB 3.0) rate at 5.0 Gbit/s........full duplex communication.:
What causes it so? Why are the speeds higher in Higher versions.
I meant to know practical hardware aspects that make it so.
Do you have any idea of the data density level even the highest capacity chips are doing now....
Oh 1TB Flash Drive cool! i didn't knew that it was in market. But still 4k-10k: would get a external hard disk!(that would be better) :)
What does that mean(data density level)?
Usb is a serial bus to get higher bus speeds the solution is easy, use high clock rates... You can get 2TB external USB drives for around 150-200
You can't just use the best of the best that's possibly available, it's about what's possible to mass manufacture which often takes years to develop from the core technology.
