uping power supply current
MrDEB
can a person build a power supply with several 78xx in parelle with each other to increase current?
one 78xx is only good for 1 amp w/ heat sink but if I put 3 78xx in parelle then we have 3 amp capacity??
of coarse add several capacitors
reason is I have a spectrum analizer schematic that I was/ am playing with using 10 - lm3916 chips. 10 leds per chip and a 2watt 15 ohm resistor connected to 9v+ and all the leds. the 3916's are sinkimg current.
I recall audioguru helped with design but the question was raised about power supply for all the LEDs??
I would post schematic but presently on different computer and can't get hoversnap to post attachement??
maybe just wait until I return to Idaho??
Another method would be to split the LEDs into sections consuming less than 1A and power each section with it's own 78xx.
Thats a viable solution
when I get back to Idaho, will look at possiablities.
Was surfing the web and found on the mondo-technology site a super probe that has a frequency countey on it. Wonder if I could use this to adjust all my displays and each filter section??
When I get back on my computer I have lots of stuff on my plate.
a digital Theremin using ADC and a MCP41010 digital pot
ordering PICs for experemintation with the two books I ordered on PICs
Doing same following PCBHEAVEN examples
Getting the bugs out of my critter ridder
getting it ready for a vechile ap
tired already!!
The Mondo Superprobe is a fun project, I've not built it myself but I think 3VO has.
PS if you're still looking for a 18F book (no BASIC though) this is a terrific book on C & asm.
Thanks, will look over link
I purchased PICBASIC PROJECTS by Ibrahim Dogan
and
PIC in PRACTICE by D. W. Smith
also took great interest in the website suggested by ??
PCB Heaven I think
got to start somewhere and the projects for the 18F over at mondo-technology are really interesting.
can't waiot to get little juney out and get her a workout.
I purchased 5 18F1320's from Allied Electronics for under $3 each
maybe learn something about converting from 16F to 18F
wouldn't hurt
Yo blueroom, I am still thinking about your manual on the junebug
great tool that deserves a complete manual. Like adapter boards, better explanation about dip switches, etc.
something catered to a newbi
I agree about the manual, let alone a complete book. I've been playing with priority interrupts and wrote the following little demo. (Even with code tags it's sloppy thanks to the MPLAB editor)
Button #1, LED #1 are high priority
Button #2, LED #3 are low priority
You can press #2 , #1
But can't press #1, #2
Turn off DIP 1 so the reset switch works after programming.
        list     p=18F1320
        include <p18F1320.inc>
        CONFIG     OSC = INTIO2, WDT = OFF, LVP = OFF
        org     0x000                ; reset vector
        bra        Init                ; goto initialize
        org     0x008                ; high priority interrupt vector
        bra        HiInt                ; goto high priority interrupt
        org     0x018                ; low priority interrupt vector
LowInt    bcf     TRISA,6                ; Light LED 3
        bcf     TRISA,7
        bsf     TRISA,0
        bsf     LATA,6
        bcf     LATA,7
        bcf        INTCON3,INT2IF        ; clear the INT2 interrupt flag
Loop1    bra        Loop1                ; endless loop
        retfie
HiInt    bcf     TRISA,0                ; Light LED 1
        bcf     TRISA,6
        bsf     TRISA,7
        bsf     LATA,0
        bcf     LATA,6
        bcf        INTCON,INT0IF        ; clear the INT0 interrupt flag
Loop2    bra        Loop2                ; endless loop
        retfie
Init    clrf    INTCON2                ; enable PORTB pullups, falling edge interrupts
        setf    ADCON1                ; make all I/O digital
        setf    TRISA                ; turn off all the LEDs
        bsf        INTCON,INT0IE        ; enable INT0 (RB0)
                                    ; RB0 is always high priority
        bcf        INTCON3,INT2IP        ; INT2 (RB2) low priority
        bsf        INTCON3,INT2IE        ; INT2 interrupt enable
        bsf        RCON,IPEN            ; interrupt priority enable
        bsf        INTCON,GIEL            ; low priority interrupt enable
        bsf        INTCON,GIEH            ; high priority interrupt enable
Loop3    bra        Loop3                ; endless loop
        END
Why not make your life simple and just buy a 3A regulator? There are lots to choose from.
3A=yes 9V=no
looked at Mouser and no go on 9v regulator at 3amps
using a 7809, and 2 mje3055, aswell as several 1 ohm resistors for under $4
as per link I posted.
a LM323T = $1.27 but not 9v?? need to recheck my figures and data sheets.
As stated I have 10 LM3916's with 10 LEDs per. the LM3916's are sinking.
In my schematic I have 1=15 ohm resistor connected as 9+v to the LEDs.
why I came up with this configuration?? Audioguru was helping design and as per his suggestion (pretty sure it was audioguru, if not I apologize)
would love to post schematic but not on my computer.
The multiple 7809s sounds viable as well, then I don't need the 1 ohm resistors but will have to redesign the boards with several 7809s incorporated or ??
That's the best solution because it spreads the power out. be sure to make a PC area to lay the 78 over and solder down as a heatsink. One square inch of copper should be enough.
