Here is a simple question that im confused on...plz can someone answer it...
Im using C18 compiler....
if i use "unsigned int".... and then subtract two integers in such a way that the one which is subtracted is greater
than the one from which im subtracting...forexample...
result = small - big;
this should give me a result that does not care about the -ve sign....am i correct?....so forexample
result = 2 - 4;
the 'result ' value then contains the variable '2'.....ignoring the -ve sign
is this correct?
please can someone correct me.
thank you
Haseeb
result = 2 - 4;
is this correct?
thank you
Haseeb
