Ultrasonic Sensor Project
I am trying to build a device which will use an ultrasonic sensor (polaroid 6500 ranging module). This device will generate a sound which the user hears through an ear-piece when an object comes within range.
Preferably the sound would become more intense as the object comes closer to the user.
Also, I don't have access to a microcrontroller and need to use only analog circuits (no programed chips allowed)
Thanks for the help
My issue is getting around not being able to use a microcontroller. I tried connecting a the sensors out put to a speaker and I got some static initially and then nothing. Do I need to build a circuit which produces noises, such as a beep, and have it hooked up between the sensor and the speaker, or am I dead in the water without a microcontroller. Also, its not important that the user know the distance between them and the object, just that when the noise gets louder as their getting closer or softer and farther away.
A sensor produces no sound and has an output current that is much too low to drive a speaker.
The sensor can vary the frequency or loudness of an oscillator. The oscillator can drive a power amplifier that drives the speaker.
Why do you need a microcontroller?
Why don't you use an ultrasonic ranging module (or make your own) that is much newer than the very old Polaroid one?
So I need to connect use the oscillator connection and increase the current going to the speaker? I just had a Polaroid 6500 Ranging Module lying around and I thought I could use it.
OK, first your issue is not being able to use a micro controller, your issue is a need to learn how ultrasonic range finding actually works as if you knew that, you would not just be connecting a rangefinder to a speaker sans any interface.
First try giving this a read and discount the uC and place a focus on the pulse trains and understand what is going on. Just note what the micro controller is actually doing. Then also give this a read as it should help you understand what is actual;ly going on. This is not difficult nor is it easy, it requires some work and learning on your part.
Ron
