Dear friends,
I am a research student in the uk and i am trying to generate ultralow frequencies. Basically its a Non destructive testing but using ultralow frequency instead of ultrasonic. I would like to know if it would be possible to generate 0-1000Hz frequencies. Can a mixer circuit achieve this kind of low frequencies.
Basically i looked into piezoelectric transducers but most of the off-the-shelf transducers in the market are of higher frequencies (1-50kHz...0.5-30MHz). The idea is to send a ultralow frequency pulse wave to one end of a steel rod (25mm-150mm dia. with lengths ranging from 2m - 100m) the wave would travel to the other end and reflects back. By measuring the time delay between the sent pulse and the reflected pulse (assuming we know the wave velocity travelling in the rod) we can then calculate the total length of the rod. So essentially i am trying to work in a pulse-echo mode using this low frequencies.
On another note, this is just out of curiosity, would it be possible to generate even lower frequencies 1X10e-6Hz (0.000001Hz) with an intensity of 120dB-200dB. Would a mixer circuit work for this kind of application
Thanking you in advance
