transmit data via RF to another PIC
mdanh2002
What is an easy way to transmit some bytes (possibly text) from 1 PIC to another wirelessly? I don't need fast speed, perhaps 1200bps or even slower will do. I am trying to find some cheap FM transceiver chips and use them to transmit/receive RS-232 data using the PIC UART module but can't find any.
Thanks, I have had a look, but the tutorial does not explicitly specify or recommend which RF modules to use. Any recommendations for cheap modules is appreciated.
It specifies the ones I used, didn't you check the hardware page?.
But it should work with any similar modules, just check the voltage requirements.
Thanks Nigel. I missed your hardware page. I was looking at the tutorial page and download the ZIP file of the tutorials only. Will try to look for these RF modules in my local electronics shop.
Can I use this module to transfer UART data?
Specifications:
* Type: RF radio
* Data rate (max): 10KHz
* Range: 100m (330ft)
* Carrier frequency: 315MHz
* Power supply: 5V - 6V
* Output type: square wave
* TX dimensions: 17 x 13.5mm
* TX pin length: 5.55mm
* RX dimensions: 32 x 14mm
* RX pin length: 7mm
* Brand new and unused
Specifications:
* Type: RF radio
It looks to be OK.
