Note: This feature currently requires accessing the site using the built-in Safari browser.
Does it burn the transformer
Hm, I think you should use a 500V to 6V transformer made for whatever frequency you require.Then what transformer should i use to convert 500v ac to 6v ac
Where are you obtaining the 500v? presumably it is single phase?Can i connect 500 v ac supply to a 220v ac to 6 v step-down transformer
Been there, done that, works well.then a simple and cheap way would be to use two (identical) 240V to 6V transformers - put the primaries in series, and the secondaries in parallel - job done!
But you have to get the phasing correct, otherwise the transformers will be destroyed.
