Tps 3513
valor
Anyone know about TPS3513? I m building a power supply. I need to do a power good circuit. i do not understand the PGI pin of tps3513. Can anyone please tell me or guide me?
I asume that you've read https://focus.ti.com/lit/ds/symlink/tps3513.pdf
That says:-
Power-good input. A low level indicates that power is not good, while a high (>1.2V) indicates that power is good.
I think that it is there so that a signal from the transformer can be connected to the TPS3513 to make sure that the power good signal stops as soon as possible when the mains fails, before regulated voltage starts to reduce.
With only a cursory reading of the data sheet, it looks to me that PGI is like an ENABLE input. It shuts the TPS3513 down if something upstream thinks there is a problem (missing ac?)
That says:-
My project is building an atx power supply. The input of my circuit is from an external PSU, therefore i do not have a transformer.. So, can u tell me where do i connect to? Thanks
You should connect it to a potential divider that gives just over 1.2 V when the PSU is at full voltage.
If you don't want the input, wire it to 5 V.
So u mean is, if i dont want it to connect to the input or a voltage divider of >1.2V, i can just connect to 5v?
I think that is how it works. However, if the mains does fail, you'll get very little time to react to a loss of power.
