touch screen button debouncing
drkidd22
Hello,
I have a program up and running and displaying a button on the touch screen, but I'm having some issues trying to get turn the LED on/off with the button. Basically one press should turn the led on and the second press turn it off assuming it's initialy off. Below is the code, I tried doing different configurations, but I think I might be having some denouncing issues as the led sometimes blinks and turns on and stays on.
#include "main_BasicLCDsetup.h"
#include "GDD_Screens.h"
#include "periphDev.h"
extern float voltage_x1000;
// Configuration bits
_CONFIG2(FNOSC_PRI & POSCMOD_XT & IESO_ON & FCKSM_CSDCMD & OSCIOFNC_OFF) // Primary XT OSC with PLL
_CONFIG1(JTAGEN_OFF & FWDTEN_OFF & GCP_OFF & BKBUG_OFF & COE_OFF & ICS_PGx2 & WINDIS_OFF)   // JTAG off, watchdog timer off
WORD    	updateBTN1 = 0;
int main(void){
int	BTN1st = 0;
	EEPROMInit();   					// initialize EEPROM
    TouchInit();    					// initialize touch screen
	GOLInit(); // initialize graphics library &
if(GRAPHICS_LIBRARY_VERSION != EEPROMReadWord(EEPROM_VERSION)){
        TouchCalibration();
        TouchStoreCalibration();
        EEPROMWriteWord(GRAPHICS_LIBRARY_VERSION,EEPROM_VERSION);
 TouchLoadCalibration();
char val[10];
double voltAVG;
int i;
GOL_MSG msg; // GOL message structure to interact with GOL
Initialize the main screen created with Graphips Display Designer
this function resides in the GDD_Screens.c file which is automatically
generated by the designer.
CreatemainScrn();
//initADC (ADCIN);
while(1)
        if (GOLDraw()) {				// Draw GOL object
        	TouchGetMsg(&msg);   		// Get message from touch screen
        	GOLMsg(&msg);        		// Process message
[COLOR="red"]if (updateBTN1 && !BTN1st)  //This is where I'm having problems
		__delay_ms(20);
		TRISDbits.TRISD3 = 0;
		LATDbits.LATD3 = 1;
		BTN1st = 1;
else if (updateBTN1 && BTN1st)
		__delay_ms(20);
		LATDbits.LATD3 = 0;
WORD GOLMsgCallback(WORD objMsg, OBJ_HEADER* pObj, GOL_MSG* pMsg){
WORD objectID;
objectID = GetObjID(pObj);
if (objectID == mainScrn_BTN1) {
		if (objMsg == BTN_MSG_PRESSED) // check if button is pressed
    			updateBTN1 = 1;
return 1;
[/COLOR]
WORD GOLDrawCallback(){
    return 1;
Any help will be appreciated. I think it would be the same idea if a mechanical switch was being used, but I have not been able to accomplish that either.
After you get a touch screen press ignore the display for a period of time. I would start with 1 second and decrease the time to the point where the action feels natural.
If you do not get any false triggering you are done.
20ms..... Think of the user... I know that 20ms is approximately how long bounce can be... But you have to be realistic. When I poll a button I try to use 250 - 300ms for a sounder to beep, even this is quite fast in human terms.
Ian
