Coming from a mackie powered subfoofer I suspect the transformer (part no. c1t51) to have a problem as it blows the fuse when I connect it.
It has 2 primary lead pairs (115/230v) as specified on the label : black/red and blue/white
When used for 230v, black and white are connected (under the circuit board plug) so mains is on blue/red.
My resistance readings are as follows (black/white not connected to plug so just the wires coming out of the transformer)
red-black = 2.4 ohm
blue-white = 2.4 ohm
They are equal which seems good
but strangley enough as the following pairs don't form a winding according to the label
black-blue = 2.8 ohm
black-white = 1.6 ohm
red-white=1.7 ohm
red-blue = 2.9 ohm (red-blue measurement while connecting black/white remains 2.9 ohm ...????)
Does this mean that there is a short circuit in the two primary windings or is there realy just one primary winding with 4 leads connected to it at different locations?
I know that understanding what the problem is won't fix it but it would be satisfying to understand.
thanks,
John
red-black = 2.4 ohm
red-white=1.7 ohm
thanks,
John
