Tmro 1 Hour Assembler
medallo21
Hello friends,
I want to temporizer by means of tmro 6 hours as of the moment at which pic ignites, some of you can give an example or help me me with asm.
Thank you very much
Nigel Goodwin said:
TMR0 is the most useless of the timers, I would suggest you use the far better TMR2 instead, which is used in the 7 segment and 8x8 LED tutorials for the multiplexing.
I like TMR0 :)
With a proper crystal it's makes an awesome RTCC timebase Jiffy, it's lack of love means it's almost always available.
blueroomelectronics said:
I like TMR0 :)
Except to use it as a RTCC of any accuracy you need to compensate for it's limitations, it's not just 'load and run' like TMR2.
What limitations? With a proper crystal like 9.8304MHz it works like a charm, serial ports too.
Check the technical bulletins, for an accurate RTCC you have to compensate for the manual reloading of the timer, there was loads about it on the PICList back in the distant past.
Not if you don't reload it. This will keep good time with a 4MHz crystal.
//timer 0 prescaller set to 16
Interrupt{
    if(TMR0IF){
        ticks-=4096;
        if(ticks<0){
            ticks+=1000000;
            Seconds++;
	TMR0IF=0;
//or, to keep to integers,
Interrupt{
    if(TMR0IF){
        ticks-=64;
        if(ticks<0){
            ticks+=15625;
            Seconds++;
	TMR0IF=0;
