time delay + adc problem
sahu
I'm facing problem time delay during dual ADC i\p at same time.
int ProcessMains(void)
    ch_0 = getchreading(0);
    Process_ch_0();      // Do something with ch_0 o\p lod sence
     if (ch_0>800)  // lod 130 % Wait 6 min
        Delay60000ms
       return(OVER_LOD_SENCE);
    ch_1 = getchreading(1);
    Process_ch_1();      // Do something with ch_1 o\p volt
       if (ch_1>1000)
       return(HIGH_VOLTAGE);
        if (ch_1<950)
       return(NORMAL_VOLTAGE);
Actually I want if (ch_0>800) mcu wait 6 min,
when ADC reach >800 delay start hear
if (ch_0>800) yet 6 min, then return(OVER_LOD_SENCE)
if (ch_0<800) during 6 min. it will go predefine return abc case.
im using CCS C .
You do realize, that function will ALWAYS return over_lod_sense.. Delay6000ms hasn't got a ";" at the end
it should read
       Delay60000ms ;   // end statement
now it will only return O_L_S when it evaluates ch > 800..
one main problem is hear
when ADC reach >800 delay start hear(6 minutes)
ok |||
between delay(6 minutes) other ADC ch_1 not working
if (ch_1>1000)
ETC
In you original code
        Delay60000ms                      EVEN WITH THE MISSING  ';'
       return(OVER_LOD_SENCE);      THIS IS EXECUTED ANYWAY
    ch_1 = getchreading(1);            WHICH MEANS THIS NEVER IS.
       if (ch_1>1000)
        if (ch_1<950)
yes |||
I think our wires were crossed.... What is it you want the function to do....If the flow is like ths..
read ch_0..
process ch_0
if ch_0 is bigger than 800 then delay 6 seconds then return O_L_S (finished)
read ch_1..
process ch_1
if ch_1 is bigger than 1000 then return H_V (finished)
or return N_V (finished)
In either case if ch_0 is bigger than 800 then ch_1 is ignored.
Are you wanting to halt like this.
    int x = 600;
         while(x--)
             Delay1000ms;
             if(ch_0 < 800) return abc;
    if (ch_1>1000)
    if (ch_1<950)
you'll need to keep acessing the ch_0 reading to check if it goes lower.
thank u sir for Ur guidelines
above change work as u say .
but my main problem is hear .....
as i want " in case if ch_0 is bigger than 800 & it(mcu) sty in delay mode & during delay mode ch_1 is don't ignored "
because ch_0= current sens adc & ch_1= voltage sens adc.
so if (mcu) sty in delay mode & ch_1 is ignored by mcu & ch_1 >1000 (HIGH_VOLTAGE ) .we found HIGH_VOLTAGE . mcu not go high volt cut mode
it is one error .
set a return value of 1 = O_L_S, 2 = ABC, 3 = HV and 4 = NV
   static int x = 0;
   int returnvalue = 0;
      if( x++ == 600 )
         returnvalue  = OVER_LOD_SENCE;
      Delay1000ms;
   else(ch_0 < 800)
      returnvalue  = ABC;
   if (ch_1>1000)
       returnvalue = HIGH_VOLTAGE;
    if (ch_1<950)
       returnvalue = NORMAL_VOLTAGE;
    return returnvalue;
The only way I can figure it out
im right ?
  ProcessMains return values
#define NORMAL_VOLTAGE 0
#define HIGH_VOLTAGE 1
#define LOW_VOLTAGE 2
#define OVER_LOD_SENCE 3  // 130 % yet 6 min
Or.... a better way would be to return flags 1,2,4,8 That way you can return and assess more than one return value....9 would be 1 and 8 etc...
Well.. If you have four return values....and lets say ch_0 is out of range ie.. >800, then you call ch_1 will overwrite the return value. and you still have a situation where ch_1 returned ok and ch_0 return wasn't seen... So!! if O_L_S was bit 0, ABC was bit 1, High voltage was bit 2 and normal voltage was bit 3 you would see both ch_0 and ch_1 return conditions (actually you only need two as there are only two conditions for both )
