That's not bad at 5 bucks. I'd imagine the code is much easier too if you are just interested in direction of tilt.
Atomsoft:
I've got a mirrored pdf of an eagle layout for the LGA-14 that I made that takes it to a .1 inch header for a breadboard if you'd like it, though it sounds like you may already have it. It's probably not very good as far as design goes, but I was able to get it working this past weekend.
I just fab'd the board with PNP blue iron on paper, pre-drilled for the header, then dabbed solder paste on the pads with my finger, dabbed a bit of flux, then a little more solder paste to make a mud. I then spread it so the pads were kind of showing through the paste and then placed the component. On my second board I wasn't getting any reading on two of the axis so I just pushed more solder paste against the IC where the pads are for those axis and stuck it back on the hot plate. Both were working fine until I messed around and reversed the polarity on one of them and fried it.
