The last 'nibble' of the puzzle
SwingeyP
Hello again.
I have a 'word' value which could contain any 4 digits for example 6F12 (the number can change)
I want to convert this to the ascii equivalent of the number, so 6=0x36, F= 0x46, 1=0x31, 2=0x32
how do I do it?
My attempt ...
Dim value As Word
Dim b1 As Byte
Dim b2 As Byte
Dim b3 As Byte
Dim b4 As Byte
value = 0x6f12
b1 = ShiftRight(value, 12)
b1 = b1 And 0x0f
b1 = b1 + 0x30
b2 = ShiftRight(value, 8)
b2 = b2 And 0x0f
b2 = b2 + 0x30
b3 = ShiftRight(value, 4)
b3 = b3 And 0x0f
b3 = b3 + 0x30
b4 = ShiftRight(value, 0)
b4 = b4 And 0x0f
b4 = b4 + 0x30
It's not quite right - any ideas?
Regards - Paul
you have the right idea but you just left the most important things out such as platform, name and version of programming language...
it looks like some mix of basic and C syntax.
for example in VB.NET, your example would look like
        Dim value As UInt16
        Dim b1 As Byte
        Dim b2 As Byte
        Dim b3 As Byte
        Dim b4 As Byte
        value = &H6F12
        b1 = (value >> 12) And &HF
        b2 = (value >> 8) And &HF
        b3 = (value >> 4) And &HF
        b4 = (value >> 0) And &HF
Hi. Thanks for the reply.
It's written in OSHON pic basic.
Having slept on it I think this will work
Dim value As Word
Dim b1 As Byte
Dim b2 As Byte
Dim b3 As Byte
Dim b4 As Byte
value = 0xabcd
b1 = b1 And 0x0f
If b1 > 9 Then
b1 = b1 + 0x37
Endif
b2 = b2 And 0x0f
If b2 > 9 Then
b2 = b2 + 0x37
Endif
b3 = b3 And 0x0f
If b3 > 9 Then
b3 = b3 + 0x37
Endif
b4 = b4 And 0x0f
If b4 > 9 Then
b4 = b4 + 0x37
Endif
As b1 b2 b3 and b4 can only contain the values 0 to F once the shift is done.
It's not pretty and i'll convert it to a function later but it seems to work. - It doesn't take into account that the letters will always be uppercase. I'm not sure that matters though.
Regards - Paul
something like this
Dim value As Word
Dim n0 As Byte
Dim n1 As Byte
Dim n2 As Byte
Dim n3 As Byte
AllDigital
value = 0x6f12
Call word2nibbles(value)
n3 = nibble2ascii(n3)
n2 = nibble2ascii(n2)
n1 = nibble2ascii(n1)
n0 = nibble2ascii(n0)
End
Proc word2nibbles(word1 As Word)
	Dim temp1 As Word
	temp1 = word1 And 0x000f
	n0 = temp1.LB
	word1 = word1 / 16
	n1 = temp1.LB
	word1 = word1 / 16
	n2 = temp1.LB
	word1 = word1 / 16
	n3 = temp1.LB
	word1 = word1 / 16
End Proc
Function nibble2ascii(byte1 As Byte) As Byte
	nibble2ascii = LookUp("0123456789ABCDEF"), byte1
End Function
