Vizier87
Active Member
Hi guys, been a while.
I'm attempting to run an SSD1306 display with this tutorial. The programs compiled pretty ok I guess. The PIC I'm using is PIC16F1938.
The display I'm using didn't have the RST/CS pins. Only SCL, SDA, Vcc and GND pins.
Here's the code:
After compiling and burning the .HEX, didn't work. That's fine, troubleshooting then.
Then I checked RC3 and RC4 with a scope. No signals/clocked output observed, just a DC output.
So I tried checked the I2C hardware by a simple library code:
And no clocked signals either from RC3 or RC4.
Anyone can point me in the right direction here?
Thanks.
Vizier87
Here's the code:
C:
Interfacing PIC16F887 microcontroller with SSD1306 OLED display
C Code for mikroC PRO for PIC compiler
Internal oscillator used @ 8MHz
Configuration words: CONFIG1 = 0x2CD4
CONFIG2 = 0x0700
This is a free software with NO WARRANTY.
http://simple-circuit.com/
// define SSD1306 reset pin (if available)
//#define SSD1306_RST RD4_bit
//#define SSD1306_RST_DIR TRISD4_bit
#include <SSD1306.c> // include SSD1306 OLED driver source file
char *text = "000\0"; // '\0' is the string terminator
unsigned short i = 0;
int i_= 0;
sbit Indicator at rb4_bit;
void Alert (unsigned int z){
for (i_ = 0; i_ < z; i_++){
Indicator = 1;
Delay_ms(1000);
Indicator = 0;
Delay_ms(1000);
Indicator = 0;
void main() {
trisb4_bit = 0;
Alert(3);
trisc = 0;
portc = 0;
delay_ms(500); // wait half a second
I2C1_Init(400000); // initialize I2C communication with clock frequency of 400KHz
// initialize the SSD1306 OLED with an I2C addr = 0x7A (default address)
SSD1306_Init(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
// clear the screen
SSD1306_ClearDisplay();
SSD1306_GotoXY(1, 1); // move cursor to column 1, row 1
SSD1306_Print("Interfacing PIC16F887 with SSD1306 OLED display"); // print text
delay_ms(5000); // wait 5 seconds
// clear the screen
SSD1306_GotoXY(6, 2); // move cursor to column 6, row 2
SSD1306_Print("Hello world!");
delay_ms(2000);
SSD1306_StartScrollRight(1, 1);
delay_ms(3000);
SSD1306_StopScroll();
SSD1306_StartScrollLeft(1, 1);
delay_ms(3000);
SSD1306_StartScrollDiagRight(1, 1);
delay_ms(3000);
SSD1306_StartScrollDiagLeft(1, 1);
delay_ms(3000);
delay_ms(3000);
delay_ms(2000);
while(1) {
text[0] = (i / 100) % 10 + '0'; // extract hundreds digit
text[1] = (i / 10) % 10 + '0'; // extract tens digit
text[2] = i % 10 + '0'; // extract ones digit
SSD1306_GotoXY(10, 5);
SSD1306_Print(text);
i += 1; // increment i
delay_ms(500);
// End of code.
C:
void main(){
trisc = 0;
portc = 0;
PORTB = 0;
TRISB = 0; // Configure PORTB as output
I2C1_Init(100000); // initialize I2C communication
I2C1_Start(); // issue I2C start signal
I2C1_Wr(0xA2); // send byte via I2C (device address + W)
I2C1_Wr(2); // send byte (address of EEPROM location)
while (1){
I2C1_Wr(0xAA); // send data (data to be written)
I2C1_Stop(); // issue I2C stop signal Delay_100ms();
I2C1_Wr(2); // send byte (data address)
I2C1_Repeated_Start(); // issue I2C signal repeated start
I2C1_Wr(0xA3); // send byte (device address + R)
PORTB = I2C1_Rd(0u); // Read the data (NO acknowledge)
Thanks.
Vizier87
