Tesla MH7489 -- also 7908 (2112n) 14? pin dip IC
sruger
I've look arout the web quite alot for these 2 chips, the Tesla is a 16X4 static ram and the 7908 is a 14? pin dip, but the symbol on the chis is a big S.
Thanks in advance,
David
The Tesla 16x4 static RAM (MH7489) I have nothing at all on right now. As to the other chip, I suspect that the 7908 is a date code, and that the chip type is the 2112. I am aware of two different DIP-14 chips using that base number:
  • high & low side driver **broken link removed** and **broken link removed**
  • quad op-amp **broken link removed**
You should be able to determine which you have (if it is in circuit) by its associated circuitry... :)
Thank you ChrisP,
The chip was supplied to me for an electronics course, and the quad op-amps seems the most likely, Now that you mentioned it, I think it had JRC on the package, The S may have been on another IC. Another student had the datasheet on the MH7489, but I didn't get a chance to copy it.
Thanks Again,
David
Maybe this is enough...
