Temperature control
Power-U
Anyone know any ciruits or any web pages that has cirduits for a green house temperature control ciruit.
What sort of control do you want ? simple on-off control of a heater or full PID ?
What size heater ?
If the idea is to turn on an exhaust fan when the temperature rises in the greenhouse, you might want to check out your local hardware store. They sell a bi-metal contact in a 1/2" x 2" case. When the temp rises, the two metal strips contact and hold until the temp falls 10 degrees F. The "turn-on" temperature is adjustable from 95 - 120 degrees F. They are made for attic fans, cost under $5, and will handle a couple of Amps.
so you need something so that when the tempersture resches a certain value you will have a fant turned on and when it drops to certain value the fan will stop. or use a heater instead to make hotter?
