Telphone
satchid
Dear all,
Please bear with me, I have it difficult to explain what I am looking for.
I want to record a piece of music via the telephone line, but when an A (la) is played, then the answering machine hears this as an end of call and switches off.
To solve this I want to know the following:
How can i detect on a telephone line that the calling party putted down the hook, and then automatically do the same on the near side. (similar to an answer machine).
I can not use the end call (blocks of 440Hz separated by blanks) signaling of the telephone line because then it switches the line of when someone plays an A on an instrument.
Could I do this this way: let a picaxe detect the tone (blocks of 440Hz separated by blanks) and form an other slow square wave as a result of the blocks of 440Hz. With other words) when the 440Hz is on the signal is high and low when there is a silence. Then count a few of the blocks, and then switch the line off.
How would I proceed with the code? I have little experience with microprocessors.
If someone has a better idea to solve tis problem, I would appreciate the info.
Willy
PS: A picaxe is an easy to program microprocessors.
the simplest detection that comes to mind is an absence of signal.
If nothing is present for a short period, maybe 20 seconds ?
then the machine could be set to hang up.
Using tones and notes would be troublesome,
as they could appear in music.
A telephone is not a good medium for music,
as you probably know.
Best of luck with it, John :)
