Tcn75a i2c
Ian Rogers
User Extraordinaire
Forum Supporter
Most Helpful Member
// Setup Config reg for 12bit A/D conversion
SWStartI2C(); // Start
SWPutcI2C(0x90); // Address byte (write)
SWAckI2C();
SWPutcI2C(0x01); // Pointer (config)
SWAckI2C();
SWPutcI2C(0x60); // Data (12bit A/D conversion)
SWAckI2C();
SWStopI2C(); // Stop
// Set pointer to temperature reg
SWAckI2C();
SWPutcI2C(0x00); // Pointer (temp)
SWAckI2C();
Why do you set the pointer here! Do you not set the pointer when you read.. From the datasheet it looks like you MUST set the pointer each read.
ARandomOWl
No I don't. As I said, the code does work. But I only get a 9 bit reading unless I run the init routine twice. Then I get the desired 12 bit reading.
ARandomOWl
Yes, that's a good point. The circuit is currently constructed on breadboard with long lengths of kynar wire attached to the TCN75A (it's an 8 pin MSOP).
EE World Online Articles
Loading
