zachtheterrible said:
Its not that audio, it runs fine off of 4.5v from AA batteries. The circuit that I'm doing is an RX module, HT12E decoder, and a 555 to drive a piezo buzzer when the decoder output is activated.
I did some calculations, and I'm not sure if they're right but here they are:
@ 625HZ:
100uf cap- 2.5 ohm capacitive reactance
1000uf cap- .25 ohm capacitive reactance
100uh ind- .39 ohm inductive ractance
1000uh indu- 3.9 ohm inductive reactance
I'm thinking that I'll have to use capacitors instead of inductors because it would take a ridiculously large inductor to introduce any sufficient reactnace to 625HZ. Unless my calculations are off? I'm still struggling with converting uF and uH to F and H. I don't have a scientific calculator unfortunately.
A low ESR 10000uF capacitor would probably work because it would only have .025 ohm capacitive reactance.
As audio said, your design is perhaps sensitive to ripple (which most likely can be made immune) if you ran it off of batteries and it works, it is because the batteries do not have a ripple voltage associated with them.
Regarding ripple voltage, the main thing to understand is that when your transformer is not charging the output capacitor and supplying load current, the capacitor all by itself is supplying the load current. Over a small interval of time , this discharges the cap causing the voltage to droop (the cause of the ripple voltage).
For a given ripple voltage:
1) a larger capacitor can supply higher currents for a half cycle of 625 Hz (or whatever it is)
OR
2) a larger capacitor can supply lower currents but for longer before the voltage drops enough to meet the ripple spec.
To reduce ripple magnitude:
1) larger cap - provides more storage for load current.
2) higher running frequency - replenish the capacitor more often per unit time.
3) lower the load current - draw less from the capacitor to begin with.
All these help. You mentioned big inductors. keep in mind a 10,000 uF cap may not be all that much smaller!
Good design = ripple current is not an issue at the expense of a giant output capacitor.
Better design = ripple current is designed to be such a value that the load has no problems with it. Output cap is only as big as it needs to be to meet ripple spec.
Best design = load is immune to any power supply ripple and in some cases, an unregulated supply can be used. A small smoothing capacitor is usually a good idea though..
Which way do you want to go with all this?
