switch type on input??
yfx4
For my motorcycle turn signal I need to alter the stock switch mechanism. The contacts are OK for a fully analog system but do not provide consistent contact for a digital one. Since the switch is in a 'box' on the handlebar I will have limited space and POSSIBLE moisture. I considered a magnet on the existing switch lever and either a Hall Sensor or a teeny reed switch to detect proximity of the magnet and trigger the left or right event. I would seal them up in heatshrink or epoxy to waterproof it when tested.
Any other ideas??
Which do you think would be better? The reed switch is simple but I worry about the vibration and since the space is small can I really get the magnet far enough away to open the contacts?
For a Hall sensor do I just connect power to the sensor and the output to the PIC or do I need some sort of interface like this: **broken link removed**
of course I will have a pull up resistor enabled on the pic (right now a 16f1829 but open to change) for stability of the input port.
Thanks in advance!!!
Perhaps just make the contact 'consistent' with a suitable debounce circuit?
Good point. I'll elaborate further.
The Bike is a Honda VTX with L-off-R on one switch. Stock it latches on and requires a push to unlatch. I want a timed self cancelling system requiring a momentary contact--so I don't ride miles with my TS flashing. Modifying the switch to momentary makes it so the contacts do not consistently contact. The bounce would be easy. Contact not so much. I have disassembled, tweeked, lubed, etc with less than consistent results. I thought adding a weather resistant (for when I wash it or get caught in rain) switch in the existing mechanism would solve the contact issue. Just not sure of the best route though.
What do you mean by the above statement?
You have two issues:
1) Provide at least 10 mA of wetting current. That keeps the contacts clean.
2) Provide a hardware of software debounce.
Analog meaning a thermal-based flasher unit that requires the switch to stay in the on position for the flasher unit to work. Digital meaning a system that is programmed and is triggered by a momentary contact switch. The stock switch makes good contact if pushed and held. Not so good if push and release. It is a cheap design with dimpled brass tabs that slide in a plastic carrier. The springiness of the brass provides contact--they get stuck in the plastic sometimes. The vibration of the bike knocks them loose if they sit in place--it just does not function well as a momentary switch. I have seen better contact in cheap slide switches I took apart to see what was inside.
I am probably using the wrong descriptors for the switch.
A monostable circuit could be made which would provide a fixed duration output pulse (e.g. 10 secs) regardless of whether the switch was latched on or made a 'chattering' contact.
