Switch on/off over internet
tovjreddy
Can any one give me a working circuit to switch a 3 phase motor at my farm house over internet ?
Thanks in Advance.
JVReddy
Good Afternoon,
I don't know where you are from, but you can try and get something like this where you are.
You can run it with a relay to switch on and of from where you like.
To turn things on/off over the internet I use one of these $100 boards.
There are several similar boards for sale.
The output is 0/5 volts that need a transistor and relay to drive your motor.
You will need to learn a little about the internet and TCPIP. The board comes with software that works and will do what you want. I modified that software to get a home control system working. (I don't know much about HTML programming) See my system at
gradllc.com/internet.HTM
(This is a copy of my system not the real thing! I don't want you turning lights on in my house)
i was looking for something else when i came across this sounds fun . but the link is dead any chance of an updated link.
thanks
@Ronsimpson
webpage said:
You are talking to a 8051 computer with 40k of flash running at 20mhz.
Where on earth did you find a processor running at 20 milli-hertz? Curious. I do think you mean 20 MHz. Hertz also gets capitalized because it's a proper name.
m is milli and M is mega
I'm also not sure what a Switchs is. Switches, maybe?
You can always create a simple TX/RX circuit using 2 PIC microcontrollers and EUSART then write a simple computer program to comunicate with your PIC at 9600bps over RS232. The program(server) receive connections from a trigger application(client) which you can use to send a signal. Alternatively, you could create a simple PHP interface to send the control signal.
