Switch high / Switch Low (was Pic microcontroller)
naim
Someone can give me an example of switch active low..and active high...used for pic 16f877a..
ex:when we use active high circuit,so what about the program???example would help..thanks.
The only difference is using either BTFSS or BTFSC accordingly - my tutorials show how to read switches.
can u give me an example of program using "counter"..
your tutorial very useful..thanks.
i want to make program use counter.
while(1)
ex.--->input->portb.c7--->>output-->portc=0b0000001... led on 5 sc
but for 2nd time
same port input..same port output but i want led on for 10 sec.
please..
Naim.. As I explained in the other thread.. You really don't need a counter for this kind of application you need to toggle a byte value for subsequent reads of the alarm switch.
ie..
x = 0
if switch then x = 1
if switch then x = 2
if timeout then x = 0
if x then process LED
I need to know exactly what you are trying to do..
Cheers Ian
u know this Wednesday i must to present my final year project.but i think can't solve this problem.:-(
i dont now how to program it.
void main()
int i;
trisc=1; // set port as a input
trisb=0; //set port b as output
while(1) {
if (portc.f5) //read portc.f5 and switch as input button
delay_ms(2000); //two second delay
for(i=0;i<=10;i++) //use for to read funtion for ten times ex;if led it will blink ten time
portb=0b0000001; //port bo on -siren or buzzer is on
delay_ms(100); //one second delay
portb=0; //all of port b is off-alarm or buzzer is stop after sound for ten time.
delay_ms(1000) ; //one second delay
else if (portc.f4) //read port.f4 and switch as input button
for(i=0;i<=5;i++) // use for to read funtion for five times ex;if led it will blink five time
portb=0b0000001; //port bo is on -siren or buzzer will sound wiiuw..wiiuuww...
delay_ms(1000); //one second delay
portb=0; //all port b is turn off,buzzer and siren will stop sound
else if (portc.f3) // read portc.f3 and switch as input button
delay_ms(2000); //two second delay for next operation
delay_ms(1000) ;
else if (portc.f2) // read portc.f2 and sensor as a switch
for(i=0;i<=100;i++) //use for to read funtion for ten times ex;if led it will blink ten time
portb=0b1111111; //port bo on -siren or buzzer is on
delay_ms(1000) ;
above are my program.but for input portc.f2..i want a function like i said before.can u edit to me??
ok2.i can xplain it briefly...
1st...if portc.f2 got input..then the output is led blink 5sc
2nd time..the same port got input...but the i want the different output.mybe led blink 10sc
You will need to juggle this a bit, but this is how I would start
void main()
	int i;
	unsigned char state, oldstate;
	while(1)
		state = (portb & 0x2C) >> 2; // we need  2,3,4,5 so put them in low nibble
		old state <<= 4; 			// added to oldstate
		oldstate += state;			// gives us 8 possible states needed
		// other states can be implemented as you need them
		switch(oldstate)
			case 0x01:					// switch on f2
				output(1,5);
				break;
			case 0x02:					// switch on f3
				output(1,5);
				break;
			case 0x04:					// switch on f4
				output(1,5);
				break;
			case 0x08:					// switch on f5
				output(255,5);
				break;
			case 0x11:					// switch on f2 ( again )
				output(1,10);
				break;
			case 0x22:					// switch on f3 ( again )
				output(1,10);
				break;
			case 0x44:					// switch on f4 ( again )
				output(1,10);
				break;
			case 0x88:					// switch on f5 ( again )
				output(255,10);
				break;
void output(char portval, char duration)
	int i;
	for(i=0;i <= duration;i++) 	//use for to read funtion for duration ex;if led it will blink duration
		portb = portval;		//port bo on -siren or buzzer is on or LED's
		delay_ms(500);			//half second delay
		portb = 0; 				//all of port b is off-alarm or buzzer is stop after sound for ten time.
		delay_ms(500);			//half secon delay
I havent checked this through but you should get the idea... it's the basis of a state machine.
Cheers Ian
Use the switch case statement it should give a idea
switch (expression) {
  case constant-expression_1 : statement_1;
  case constant-expression_n : statement_n;
  [default : statement;]
output(1,10);------->
output(255,10);------>how to convert to be ex: portb=0b0000001
how to declare "old state"..
i can't compile it.....
.hehe---sorie for trubling u.
Ian Rogers how you post a switch case before me I sure didn't see it when I posted but thats what naim needs to get it going
Nice work Ian
Naim! No the code should compile with both... The portb should be initialized to 0 just before the trisb..
In the function output it takes two arguments portb val and duration you can call it with a statement like this
output(%0000001, 10);
this will work for you.
I am going to run this on isis to make sure its ok.
Cheers Ian
I have just compiled this with Hi-tec in MPLAB.. I had to change the delay call as mine is slightly different.
void output(char portval, char duration);
void main()
	int i;
	TRISC=255; // set port as a input
	TRISB=0; //set port b as output
	while(1)
		state = (PORTB & 0x2C) >> 2; // we need  2,3,4,5 so put them in low nibble
		oldstate <<= 4; 			// added to oldstate
		switch(oldstate)
				output(1,5);
				break;
				output(1,5);
				break;
				output(1,5);
				break;
				output(255,5);
				break;
				output(1,10);
				break;
				output(1,10);
				break;
				output(1,10);
				break;
				output(255,10);
				break;
	int i;
	DelayMs(2000); 			//two second delay for next operation
		PORTB = portval;		//port bo on -siren or buzzer is on or LED's
		DelayMs(500);			//half second delay
		PORTB = 0; 				//all of port b is off-alarm or buzzer is stop after sound for ten time.
		DelayMs(500);			//half secon delay
Cheers Ian (I had a space in the identifier oldstate, oops).
i have to compile it using mpLab??
DelayMs(500);-----can i make it like this----delay_ms(500)
is it same either we compile in micro c or Mplab??
is it can become a same thing??
I used DelayMs(500); because I haven't got a copy of your delay_ms() routine. This code is as close to ansi C as possible so it should compile on mikroC (the only differences will be PORTB "on hitec" and portb on mikroC),, either case you will see it in the compile errors.
Cheers Ian
