surge current of wires
Frosty_47
Hello,
I would like to know if there is a chart that lists the maximum surge current of AWG wires. I am close to finishing my 4000 Joule 1600V capacitor defibrillator and would be inconvenienced if the wires explode/melt away.
-Thanks
OK, I'll go along with the joke. A 1 thousandth of an inch diameter wire will easily carry 4000 joules without exploding or melting away.
Now ask a sensible question.
Ermmm I aint volunteering as his patient....:)
Why not ? I mean isn't there a hefty prize given to the family of a Darwin Nominee ?
Do you know the estimated discharge time? A joule is one watt second. If you dump it all in one second that the same as a 14.4 mega watt load at 1600 volts or about 9000 amps for one second.
Two 4/0 welding cables can take that kind of burst. they can hold a continuous duty 1000 amp submerged arc welder without trouble. Even with 20 KA peaks I doubt you would bother them one bit.
Cor!...some firework display if you shorted the leads... :)
I hate meausing cable in AWG or SWG. Cross-sectional area mm² is much easier to understand.
So you're building a defibrillator; how do you plan to spend in getting it approved?
At 4000 joules and 1600 volts its not a defibrillator. Its a vaporizer!:eek::D
Still, I would play with it!
Onderdonk vs. Preece
16 gauge copper wire: Tmelt = 1083, Area = 2581 circ mil, Time = 5 sec, Tamb = 25
E= Area in CM
B = Tmelt - Tamb in deg. C
D = 234-Tambient in deg. C
T= time in seconds.
So, E = 2581, B= 1058, D=209, T=5
Then
Ifuse = E* SQRT {<LOG[(B/D)+1]>/(T*33)}
Ifuse = 2581* SQRT {<LOG[(1058/210)+1]>/165}
Ifuse = 2581* SQRT {<LOG(6.04)>/165}
Ifuse = 2581* SQRT {0.781/165}
Ifuse = 2581* SQRT {.00473}
Ifuse = 2581* 0.0688
Ifuse = 178A
So that's 178A for 5 seconds to hit the melting temp?
What about the insulation?
The plastic/rubber insulation will burn up long before the conductor vaporises.
Jeez....I have a Tens machine for pain relief and thats enough for me....178Amps...boy you can weld with less than that....
