Strange glitch
labrat31
I have almost finished writing a program to receive and transmit strings of data. It reads a 4 byte data string from UART and sends it to RAM then transmits the data from RAM in a 4 byte string back over UART. It also has a timer so it will not lock up or loose sync if it reads 3 or 5 bytes. It works ok say 90% of the time other then this glitch, when I send data to the micro from a computer continuously with a delay in between strings say 100 mS sometimes it will miss a string and the ports flick on and off quickly even though I have no reference to ports in the program. Anyone know what this could be??
hi lab,
Is the 'sync' Timer on interrupts.??
Post your program
;#####  Receive and transmit       #####
;#####  strings of data over UART   #####
	serTx	DATA	    30H
	serRx	DATA	    31H
	byte1	DATA	    32h
	byte2	DATA	    33h
	byte3	DATA	    34h
	byte4	DATA	    35h
 			ORG 00h
;#####      Main program      #####
		ACALL SetUART	;Set up UART
		;set up pointers to load UART data string to RAM
loop:		MOV R0,#serRx	;source pointer
		MOV R1,#byte1 	;destination pointer
		MOV R3,#4 	;counte
		ACALL Rx_ram	;input UART string to ram
		;set up pointers to load RAM data to UART and output string
		MOV R0,#byte1	;source pointer
		MOV R1,#serTx	;destination pointer
		MOV R3,#4 	;counte
		ACALL ram_Tx	;output string of data from ram over UART
		ACALL loop	   ;keep doing it in a loop
;#####      	  RAM Loops        ######
Rx_ram:		ACALL Rx		;Get data from UART
		MOV A,@R0 		;get a byte from source
		MOV @R1,A 		;copy it to destination
		INC R1 			;increment destination pointer
		DJNZ R3,Rx_ram 		;keep doing till all bytes are received
		;setb P0.4		;turn off p0.4 LED after all bytes are sent
		RET
ram_Tx:		MOV A,@R0 		;get a byte from source
		INC R0 			;increment source pointer
		ACALL Tx			;transmit data byte
		DJNZ R3,ram_Tx 	;keep doing till all bytes are sent
		RET
;#####   UART Initialization   ######
;#####	 transmit and receive  ######
setUART:		MOV	PCON,#0x80	;x2 serial baud rate
		MOV	TH1,#0xF4 	;reload value 250 for 9600bps w/11.059MHz xtal
		MOV	TL1,#0xF4
		MOV TMOD,#0x20 	;timer 1,mode 2(auto reload)
		MOV	TCON,#0x40	;start timer 1
		MOV	SCON,#0x50 	;8-bit, 1 stop, REN enabled
		RET
TstOK:		MOV serRx,SBUF
		CLR RI			 ;clear RI flag
		RET
		;timer to keep sync
Rx:		MOV R4,#20	 	;delay time multiplier
AGAIN:		MOV R5,#20	 	;delay time
HERE:		JB RI,TstOK		;get byte from SBUF if IR is set
		NOP
		NOP
		DJNZ R5,HERE
		DJNZ R4,AGAIN
		ACALL st_flt	 ;exit if there is no receive in time period
		;transmit  UART
Tx:		MOV SBUF,serTx 	;saving incoming byte in A
TxH:		JNB TI,TxH 		;wait for the last bit
		CLR TI 			;get ready to receive next byte
		RET				;Return to main program
st_flt:		NOP
		;CLR P0.4
		ACALL loop		;start loop again
		END
its still a little messy and missing some comments but this is what I have so far
if u mean dose it use the Receive interrupt flag then yes. Im still self learning so I may be missing something
copying my code into “wrap code” messed up my formatting big time sorry but the .asm should look ok
Should my sync timer be on interrupts? Trying to get it working now but the interrupt only works once
ORG 23H
LJMP ser_IE
ser_IE: MOV serRx,SBUF
CLR RI
AJMP Rx_bite
