breakshift
Hi, I need to essentially step down the output voltage of a generator:
to a lower voltage that can be fed into an NI sbRIO-9631:
NI sbRIO-9631 - Embedded Device with AI, AO, DIO, 1M Gate FPGA - National Instruments
The aim is to measure the power output of the generator and provide a control signal to the engine to keep this power constant with varying load on the generator. By stepping down current and voltage and feeding this into the RIO, the power can be monitored. A current sensor is easy enough, but I'm struggling to find a device that will perform the voltage measuring/down-stepping. This is for use in a UAV, and so the electronics will need to be able to cope with a certain temperature range.
The max output of the gen is 230v, and the max analogue input of the RIO is 10v. So I'd like to get my hands on a device that will do this (need quick delivery to the UK). I've searched rss and Farnell, and other sites, but couldn't find what I need.
Failing that, I'd need to design my own. I was thinking of using a voltage divider circuit. To keep the divider output constant over temperature I could use a negative temperature coefficient thermistor in series with the divider, so that any dR in the divider circuit would be countered by a suitable dR in the thermistor, hence keeping the output constant.
So basically there must be something out there that will do this for me... and if not what do you think about the voltage divider idea?
Thanks,
Thanks,
