STB shutting off after a split second
starLED
I have a Set Top Box for TV (STB) that worked about two years fine, but now when I plug in adapter cable then power green light comes on for a split second then it shuts off, and no green on and red off light and LCD display is on.
I checked voltages randomly on board and there are 12 V, and adapter cable also measures 12 V.
STB model is NewGlee GL-c850AQ
What can be a problem?
STB box adapter is 12V 1A.
I tried two different adapters:
1) 12V 1.5A - same issue, green light power off after a split second
2) 12 0.85A - green light doesn't turn off, it flickers.
I was checking caps for short and I was wondering if this is normal.
Two caps near the main chip (CPU ?) have 072 ohms, and I was wondering can that be shorted to ground?
Other caps that I have tested are all higher then 500 ohms.
I noticed there is a black discoloration on the bottom side of the PCB under the CPU (in red circle), it can't be seen good on the image.
Can that be the sign of a damaged CPU that overheated?
Also, caps in the circle also measure 072 ohms.
It's unlikely you can test the capacitors in-circuit, it's most probably reading through other parts of the circuit.
You could always remove one that you suspect?, and check it out of circuit - and also check across the PCB where it was.
Generally on STB's, it's either the power supply electrolytics, or it's scrap - there's generally no schematic, and no spares available. And quite often, if PSU electrolytics have failed, then the HT rail increases and causes further irreparable damage.
