The nuclear welding, did you work for B&W? Did a lot of work for their R&D lab in my apprenticeship.
B&W Nuclear Operations Group Euclid, Ohio
Ron
1) The MOSFET on the 100V line is fine. I would have just turned on/off the supply.
2) The capacitors and switches are a little of a mystery. I think that will add power just after the spark starts.
3) The two diodes are what I was talking about "diode ORing". When you use two supplies and diode them together.
4) The 210V supply I do not want to use. I like the "boost up" inductor because it will make a voltage that will go up until there will be a arc.
5)The MOSFET on the right side; I don't know what it is doing. (Is the MOSFET in parallel or serial with the arc?) Parallel= To short out the arc. OR Series= The arc return current goes through the MOSFET. Either way I think it is to stop the arc.
6) (The MOSFET on 100V and the right side MOSFET )= too many parts.
