Krumlink said:A bunch of small speakers.
Nigel Goodwin said:Now come on! - there MUST be a collective name for a quantity of speakers, perhaps people can make suggestions?.
The Republican candidates?Krumlink said:A bunch of small speakers.
kchriste said:Some questions:
How much power do you want it to handle?
What impedance do you need?
If you want it to be loud, then look for one with a higher SPL spec.
Are you planning on mounting it in a sealed enclosure or is it going to sit naked outside the robot for that "fem-bot" look?
You might be able to salvage one out of an old portable radio.
sony speaker(oval type) from tv are good sound quality. size approx. 2" x 3".The best spot to mount the speaker would be on a 2x3 wall.
Generally speaking, you'll be able to get more power out of a 4Regarding impedance as long as the speaker and AMP match I am not picky.
It is a good idea because the sound off the back of the cone is out of phase with the sound off the front and they tend to cancel at lower frequencies. The only issue you'll probably encounter with an enclosure is if it isn't stiff enough and it may resonate at certain frequencies. Dampening the enclosure with sound Pollyfill is a good idea as long at it doesn't cause the rest of the circuit to overheat.Up to now I had not considered an enclosure.
That makes sense.kchriste said:Generally speaking, you'll be able to get more power out of a 4hm: speaker/amp than a 8
hm: speaker/amp for a given supply voltage.
The amp I am playing with has a 10nA Low-Power Shutdown Mode.kchriste said:You shouldn't need more than 2-4 watts to be plenty loud enough in an average sized room. Even 0.5-1W should be fine. Probably more important is to choose an amp that has a low power shutdown mode to save power because the robot probably won't spend much time speaking.
kchriste said:It is a good idea because the sound off the back of the cone is out of phase with the sound off the front and they tend to cancel at lower frequencies. The only issue you'll probably encounter with an enclosure is if it isn't stiff enough and it may resonate at certain frequencies. Dampening the enclosure with sound Pollyfill is a good idea as long at it doesn't cause the rest of the circuit to overheat.
I see you already have an amp and speaker setup..
blueroomelectronics said:I was going to have a kit with a simple 2" speaker mounted in a small Lab-easy case. If you find a design that works with as little as 5V I'd be happy to make it into a PCB.
♦ 2.7V to 5.5V Single-Supply Operation
♦ 1.4W into 4Ω at 1% THD+N
♦ 10nA Low-Power Shutdown Mode
♦ 73dB PSRR at 1kHz
♦ No Audible Clicks or Pops at Power-Up/Down
♦ Internal Fixed Gain to Reduce Component Count
(MAX9717B/C/D)
♦ Adjustable Gain Option (MAX9716/MAX9717A)
♦ BTL/SE Input Senses when Headphones are
Connected (MAX9717)
♦ Pin Compatible with LM4890 (MAX9716)
♦ Pin Compatible with TPA711 (MAX9717A)
♦ Available in Compact, Thermally Enhanced μMAX
and TDFN (3mm x 3mm) Packages
Don't let that put you off.3v0 said:Surplus and salvaged speakers are of unknown quality.
