Sound detection possibilities (ranges, reliability)
Hi all. It's been a while. Hopefully when life slows down I can get back into the hobby.
I the mean time, I had a question about sound detection possibilities.
I am envisioning some wireless on/off control without using RF or IR. Range need only be 50-75 feet. I'd want the signal to be an audio wave outside of the human hearing range, which I understand to be 50 to 20,000 hertz. I'd need probably 5 to 10 frequency ranges narrow enough and far enough from the others so as not to be "confused" with the others on the receiving end. I envision the receiver which would be encased in a small bit of material being comprised of a microphone to detect the sound and a bandpass filter to ignore irrelevant frequencies. The transmitter would be a small speaker outputting the desired frequency that is, again, outside of the human hearing range.
For example:
Consider a transmitter with 5 different buttons that cause 5 different frequencies to be emitted through one or more speakers. There would be 5 different receivers, each with a microphone (encased in a plastic container, perhaps) and a bandpass circuit that triggers an action only if that frequency is detected.
Would it be possible for one button to cause , say, a 25 hz audio signal that could be RELIABLY detected by microphone attached to a bandpass filter detecting 20-30 hz?
Then another centered around 45 hz, then another at say 20,500hz, another at 21,000hz, etc
Could this be reliably detected?
Could I ever expect a 50-75 foot range?
Are there cheap microphones and speakers capable of hearing and producing (reliably) say 20 hz to 25,000 hz?
EDIT:
Maybe I'm going about this all wrong. The ultimate goal is to be able to generate a single reliable signal without line of sight to an object up to 50 to 75 feet away for less than $1.50 in materials for all electronic components involved on both the receiving and transmitting end. I think rf is out as an option here due to cost, and IR while cheap requires (more or less) line of sight.
I doubt you'll be able to do it within that budget. A decent ultrasonic transducer alone will set you back more than $1.50 :(
What about subsonic?
Would it be possible if it were in the range of human hearing? 50-20k hz?
Not easy. Very few (if any?) small loudspeakers can reproduce infrasonic frequencies (I guess that's what you mean by 'subsonic'?)
In addition, because an infrasonic 'carrier' would be such a low frequency any coded modulation would need to be very slow. And without coded modulation, there is simply too much ambient infrasonic 'noise' in the air to be able to detect an infrasonic frequency reliably.
Ultrasonics probably offer a better option... although even cheap common 40KHz ultrasonic transducers are going to be more than $1. 50, as alec_t says.
Again, there's a lot of ultrasonic 'noise' about as well, so that's not going to work reliably without encoding either..
In short, its all going to be less reliable - and probably cost more - than a simple RF link!... :)
Many items produce low audio frequencies but not cheap small speakers.
Many expensive hi-fi speakers cannot produce above 20kHz so forget about a cheap small speaker doing it..
Just use DTMF. A handy talkie with a keypad and a decoder chip at the receiving talkie audio can do marvels.
Great idea -- except for the costing " less than $1.50" that the OP mentions!
I agree though, DTMF is a much underrated format for simple data projects....
I ignored the absurd $1.50 . Must be a mistype. For that price, at 60 feet distance, get a friend and voice him "push button 4" "now push button 3" and give him $1.50 for a hamburger. No electronic equipment needed.
Where can you buy a hamburger for only $1.50? They are at least $5.00 unless you get a little kid's size one.
Yesterday I looked at the menu at the new hamburger joint called, "Five Guys Burgers And Fries" and an ordinary hamburger by itself costs $7.50. I noticed that they display a magazine review that says "Best hamburger for $5.00".
I can order here five launchs/dinners (without meat) at $5.
Sorry for the off-topic.
I haven't been to McDonald's for many years. I hear that they soak their by-products meat in ammonia to kill the germs. Not nice. Five Guys Burgers And Fries say they DONT DOO DAT.
Last night I watched a TV documentary about Coca Cola and PepsiCo. Their incomes are 61 billion dollars and 50 billion dollars each year. The new CEO of PepsiCo is a lady from India and says their income will exceed Coca Cola soon because there are so many people in India and China buying their junk food like Lays potato chips with curry or wang flavours.
We went to a Sushi restaurant to celebrate my son's wife's birthday. All you can eat for $13.00. There was a lineup to get in. I have never eaten that much simple rice before. The rice came in many colors. Then I was hungry an hour later.
While we are off topic, lets wander around and enjoy the view!
I don't think that I have ever visited a McDonalds.
About 15 years ago I had a very tasteless burger in one of the other big chain burger shops in the centre of Glasgow.
It was late at night and I almost never go to Glasgow (it is about 200miles away from here), the other thing I remember apart from the tasteless burger in an equally tasteless bread roll, was the thought running through my head :
"I hope that nobody I know comes in here and recognises me eating this rubbish!" :nailbiting:
Making amends for continuing the off topic jaunt...
The OPs requirement for a device with a component cost of less than $1.50 would probably only be met if you subbed the job to China and asked them to make 1,000,000 of them for you.
Audio or sub-audio sounds like a bad idea which will not work reliably in a varying undefined environment.
The best I can suggest is to investigate some of the simple RF modules which can be bought quite cheaply, but probably still more than $1.50.
Smoke signals can be seen over that short distance unless it is dark outside, then Morse Code with a flashlight/torch will work.
...Audio or sub-audio sounds like a bad idea which will not work reliably in a varying undefined environment.
Well, the OP might have already read my suggestions in post #4 , but now they have been endorsed, as it were, by a 'mod', they may now have more a bit more 'clout' :)
You could modulate subsonic or supersonic frequencies with a microcontroller, which could do all the work and just use 1 frequency.
If you can get a speaker or transducer for 50 cents or so you might just manage it on that budget, if you were building lots of them then it would be easier to get prices down.
Here a pic10f200 which is more than capable of the job is 50 pence, 30 pence for an smd version, unfortunately a ultrasonic tx is over a quid.
You might be better doing it with infra red, tv remote style, rf tx is easy enough, rx more difficult esp on that budget.
