Digital Steve
I have a Sony DE 875 Amplifier which is giving me some problems. When I turn the amp on, it emits a loud cracking sound through the speakers even if the volume control is turned down.
I did some research and it appears that this is a common problem with these amps. The suggested repair is to check for cold solder joints especially around the final outputs. I went ahead and re-soldered any cold solder joint I could see, however the problem still exists.
Once the receiver is on it works fine so that leads me to think that it could be a relay problem. Here is my question. There are 3 relays in this amp ( OSA-SS-212DM3). I ordered new relays online, however they sent me (OSA-SS-224DM3). When I contacted the seller they assured me that these relays would work fine.
The coil resistance on the factory relay is 270 ohms and the replacement is 1100 ohms. Does this matter?
http://www.te.com/usa-en/product-5-1419124-6.html?q=OSA-SS-212DM3&source=header#pdp-docs-features
http://www.te.com/usa-en/product-5-1419124-9.html?q=OSA-SS-224DM3&source=header#pdp-docs-features
I appreciate all help.
Steve
Steve
