solid state relay
laki101
Hi
I'm new here
ok one problem I want to control some lights on 220v with a pic so I got a SSR (solid state relay) SHARP s202s02
now the problem is that I learned now that i need to power it up with a 1.2 v and max 30 mA so I need help to figure out a way to get that voltage
tried with some resistors but the voltage stays at 5v
Right!
And going back the the start:
"tried with some resistors but the voltage stays at 5v "
If you still get 5V across the SSR input, you either have it backwards...or its blown.
Ken
"If you still get 5V across the SSR input, you either have it backwards...or its blown."
problem is that I measured directly +>resistor>volt meter>ground
