jelliott
Is there such a thing as a solid state 'relay' (i.e. a PWM-compatible switching device) that actually behaves like an electromechanical relay, in terms of being switchable with ground OR positive voltage to the 'coil?' And can handle switching a 5 A load at 48 V, up 100% duty cycle, with only 12 V across the 'coil?'
Background: I've built a circuit (based on **broken link removed**) around a CD4047 monostable vibrator IC, hoping to modulate the power output of an electric heater based on the tach output of a brushless DC fan. This works well enough, but the whole idea for this circuit was an offshoot of my original idea for a low-speed cutoff (see this thread; the third post therein sent me off on this train of thought), and of course when the fan stops spinning, its open-collector tach (and my pull-up resistor) provide a perpetual 'high' input to the CD4047, defeating the original purpose.
It occurs to me that if I had a switching device that required both ground and +12 V to energize the load (like an electromechanical relay), I could switch the +12V with the CD4047 circuit and switch ground with the original LM2907 circuit (discussed at length in the aforementioned thread). But I'd also be open to suggestions that would allow use of the CD4047 circuit exclusively (e.g. how to adapt the fan's tach output to the CD4047 to go 'low' when it stops spinning).
