Mosaic
Hi all, this is a design concept and I am looking for inputs to refine it before trying to make it:
Battery charger sharing.
Often people have a ratio of multiple batteries to a single charger, especially those who have solar storage systems. Sometimes the charger might be an efficient and more costly MPPT unit.
How then to easily maintain multiple batteries which have multiple possible loads on different circuits?
Manual switching is one way.
I propose an automatic modular system that permits plugin, low drain, relay (or SSR) modules to manage switching the charging source to multiple batteries in a sequential manner or in a manner that permits battery prioritization. I envisage modules available in quad battery configurations with the master system accepting up to 4 add on modules for a maximum of 16 independent battery circuits.
The system sits between the charging source and multiple batteries, analyzes the current drawn by the charging battery (as well as its terminal voltage) and determines when the battery has achieved a high charge percentage before moving on to assess another battery. Also an indicator for which battery is being charged is included as is a manual over-ride for selecting which battery to charge.
Compatible Battery Bank voltages of 12 and 24V could be standard. Electronic 'fusing' (user set amperages to match the battery) for over current conditions can be a feature. A display of the active battery voltage and charge current can be a feature. Simple Visual indicators (LED blink speed) to high light the top 3 Wh consuming circuits.
A data log of the Watt hours delivered to each battery over the most recent one month period can be maintained for USB uplink or onto a micro SDcard.
A potential Wifi interface to a mobile app for monitoring and manual interventions as an upgrade.
Any thoughts?
Any thoughts?
