Software UART in C
wuchy143
Hi All,
I"m making a simple clock using the PIC12F675. I have the clock working but I'd like to take my 8 bit hour variable and send it out serially to a port pin which is connected up serially to hyper terminal(to see the data).
Could someone help me get a grasp as to how a serial transmitter would work? In this case it will never receive so I guess it's really a UAT. I'm not looking for code. Just a seat of the pants feel as to what I need to do. Leave the code up to me :)
-mike
**broken link removed**This code has been written many times and you should find many examples if you google for "software uart" or even "bit bang".
If you look at the signal levels generated by a UART it should be easy to implement in software.
The 12F675 doesn't have built-in UART capability, but there are tons of PICs that do. For example, the 12F1822 looks like it meets or exceeds all the features of the 12F675, has built-in USART, and it's cheaper. Unless you really feel like making your own software-driven UART (an effort I would certainly applaud), then I highly recommend purchasing a UART-enabled PIC.
Either way, don't forget the MAX232 (or similar) chip. The voltage levels on your serial port are very different from the logic levels of your PIC.
-Dan
