Software Uart and 12f508
be80be
Software Usart and 12f508 I was bored and been reading about backdoors. To send data out serial just using simple delays and software Usart. So i wiped this up.
It works and only using 65 of 512 program memory and 3 of 25 data.
You could use it dump some values
;    Filename:	    serial.asm                                        *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:   Burt E Ratliff                                         *
;    Company:                                                         *
;    Files Required: P12F508.INC                                      *
;    Notes:                                                           *
	list      p=12F508            ; list directive to define processor
	#include <p12F508.inc>        ; processor specific variable definitions
	__CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF & _IntRC_OSC
; pin assignments
    #define     RX   GPIO,0      ; receive pin on GP0
	#define 	TX	 GPIO,1		 ; transmit pin on GP1
;***** VARIABLE DEFINITIONS
      UDATA
	buffer     res    1
	counter    res    1
	Count      res    1
; Internal RC calibration value is placed at location 0x1FF by Microchip
; as a movlw k, where the k is a literal value.
RESET   CODE    0x000           ; effective reset vector
        movwf   OSCCAL          ; update OSCCAL with factory cal value
    goto    init              ; jump to main program
init
	movlw b'00000001'		  ; set I/O
    tris    GPIO
	bsf 	TX
	movlw	'b'               ; sets text to loads buffer with
	call	start
	movlw	'e'
	call	start
	movlw	'8'
	call	start
	movlw	'0'
	call	start
	movlw	'b'
    call	start
	movlw	'e'
    call	start
	movlw	' '
	call	start
	movlw	'w'
	call	start
	movlw	'a'
	call	start
	movlw	's'
	call	start
	movlw	' '
	call	start
	movlw	'h'
	call	start
	movlw	'e'
	call	start
	movlw	'r'
	call	start
	movlw	'e'
	call	start
	movlw	0x0A
	call	start
	movlw	0x0D
	call	start
    goto	init		  ;loop for ever
start
	movwf buffer
	movlw 0x08
	movwf counter        ; counts the 8 bits
    bcf   TX             ; set TX low
    call  BItdelay       ; delay to get a 9600 bit rate
TXLoop
    rrf   buffer ,f      ;send one bit
    btfss STATUS ,C      ;
    bcf   TX             ;
    btfsc STATUS ,C		 ;
    bsf   TX			 ;
    call  BItdelay		 ;
    decfsz counter,f     ;test if all done
    goto  TXLoop		 ;
    bsf   TX			 ;
    call  BItdelay		 ;
    return
BItdelay                 ; timing delay
    movlw 0x18
    movwf  Count
Wait
    nop
    decfsz Count ,f
    goto   Wait
    return
	END  ; directive 'end of program'
Here's an even smaller one that was used in this thread. Anyone interested in getting the most from these little chips should read the first 5 pages.
;  19200 baud, exact 52-usec bit timing (4 MHz)
Put232  bsf     GPIO,TxPin      ; send start bit
        movwf   OwTemp          ; save Tx data
        movlw   9               ; 8 data bits + 1 stop bit
        movwf   BitCtr          ; update bit counter
PutBit  setc                    ; shift in stop bits
        movlw  (52-8)/4         ; 52 usecs - 8 usec loop time
        movwf   temp            ; a 4 cycle (4 usec) loop
        decfsz  temp,W          ; W == 0? yes, skip, else
        goto    $-2             ; loop
        rrf     OwTemp,F        ; put data bit in C (W = 0)
        skpc                    ; a '1' bit? yes, skip, else
        iorlw   1<<TxPin        ; send a '0', W = 1<<TxPin
        movwf   GPIO            ; send bit, clear OwPin
        decfsz  BitCtr,F        ; all 9 bits? yes, skip, else
        goto    PutBit          ; send next bit
        retlw   0x0A            ; return <lf> char
Just 16 program words used.
Thanks Mike I could of saved some time if i new you had posted the One Wire Temperature sensor just had a look nice work.
I just had some 12f508 chips in a bunch of junk was cleaning my desk, And I read some stuff last night how to code backdoors for a Z80 figured may as well try it out on a 12f508 you have to love them small chips. First thing I did was erase the ocscal setting. Couldn't figure how I did that. I hooked mclr to wrong place LOL.
Thanks agin for the post I'm going to read all of now. I hope you have a good year Mike. big 2011 never figured I would see that LOL
Hi Burt,
Happy New Year.
It was a fun project to do and myself and Mike (K8LH) had fun optimizing it.
