Smart card reader/writer using JDM Programmer
manish12
I recently devlope the multi programmer for PIC ,after some bugs it is ok .
Now , i am using IC-PROG software for the same [ more chip get varified with this ] , basically it is a jDM programmer so winprog is also applicable [ with this less chip get varified , may be my prob. / hw prob].
After this i try/go for smart card but suitable information is not found about pin dia. at last got some idea about connection but still CLK pin missing.
can i know the exact procedure for r/w for smart card ? from you.
is there adapter required ?
There is 24xx adapter which is not using clk pin , i try this for 24xx chip.
if it is ok , it can be ready for you if it required [ inyour solution].
i know all primary data , you can assume !
Nigel Goodwin sir expected.
Nigel Goodwin
Super Moderator
Most Helpful Member
Only some smart cards contain PIC's, other contain different devices - of the PIC ones many also contain an I2C EEPROM. However, the EEPROM isn't externally accessible, you need to write a program to run in the PIC that copies the required data to the EEPROM.
The only hardware required is a card socket wired to your PIC programmer, plus an external colck (to make the PIC run) if you want to write to the EPROM.
EPE did a full project not too long ago.
EE World Online Articles
Loading
