Smallest way to switch 1-10v 20ma with 240v
Scarr
Hi All,
What the smallest relay with 240vac a coil that you know? or is there a solid state way of switching that is small keeping in mind the 5v is monitored by a MCU and so needs to be a constant ON / OFF switch
Thx
Scarr
Something utilizing an opto-isolator. However, by the time you add the high-voltage capacitor, diode, current limiting resistor on the input side, it will not be very small...
Here are some relays.
Hi All,
You need to give far more details of what you're trying to do?, however a relay sounds a very poor choice whatever you're trying to do.
You can get ac opto isolators, just an opto with 2 back to back led's, you could drive the leds from ac via a capacitor and resistor.
Here is about the simplest opto-coupler circuit that won't burn up or kill you... and doesn't use huge capacitors. C2 can be a small disc ceramic.
It detects the turn-on of the AC almost immediately, but it takes it a while to realize that the AC turned-off. R3 could be the "weak-pull-up" inside the PIC. Note that the input resistors are half Watt. It is active-low at the PIC input.
Here is a circuit that relies on the electromagnetic coupling to a wire placed near the mains cable required to me monitored.
spec
A submini neon bulb and a photodiode in a black plastic tube would work. ~1/4" round by 1/2" long. ;)
