Single Bit
chandu13
Hay
In 8051 pins are bit addressable using sbit (Keil-C51) so I can declare input switch & out put LED as
Ex:
#include <REG51.H>
sbit SWITCH P1^1
sbit LED P1^4
How to declare the input switch & out put LED in LPC2114 using Keil-ARM
Regards
chandu
i know nothing really but i can give you a tip on how to find the answer. Since it seems to be a simple question meaning its the basis of most of the operations. Try looking at some application (app) notes. And you will usually find the answer quick.
Hay
Ex:
#include <REG51.H>
sbit SWITCH P1^1
sbit LED P1^4
Regards
chandu
Atom is correct, and you should be able to find all you need here:
NXP (founded by Philips) LPC2114
I don't know why you couldn't find this yourself? :confused: :D
Bit
Hay
I am switching LED on & off using following code
#include"LPC210x.H"
#define LED1 0x00000800 //LED connected to the P0.11
#define LED2 0x00000400 //LED connected to the P0.10
void main()
IODIR=0xFFFFFFFF;
while(1)
delay();
IOSET=LED1;
delay();
IOCLR=LED1;
delay();
IOSET=LED2;
delay();
IOCLR=LED2;
I have seen some different code in the INTERNET
IOSET_bit.P0_11 = 1; //set P0.11t to 1
IOSET_bit.P0_10 = 1; // set P0.10t to 1
IO0CLR_bit.P0_11 = 1; //set P0.11t to 0
IO0CLR_bit.P0_10 = 1; //set P0.10t to 0
How this code will work
In the #include"LPC210x.H” file all the registers are the 32 bit register addressable
Regards
chandu
Hay
#include"LPC210x.H"
void main()
IODIR=0xFFFFFFFF;
while(1)
delay();
IOSET=LED1;
delay();
IOCLR=LED1;
delay();
IOSET=LED2;
delay();
IOCLR=LED2;
Regards
chandu
That's great Chandu! Glad you got an LED flashing, now you should be able to do what you want with that part. :) Your source is MUCH more readable than the other example you give. :D
The other code works by making the statement ( could be a macro, I'd have to spend time..) true. It is somewhat obscure, and quite anoying.
I could say some very negative things about the person who wrote the other example, but then that would make me as bad as him or her. :p
The code you found on the web is pretty much a direct representation of the hardware.
The ports on the chip are accessed through registers: SET, CLR, DATA, READ, and HIZ. I do not remember the exact names given.
DATA is merely an output data latch and READ picks up the voltage on the pin so if you SET a pin that is pulled to GND externally the READ returns a ZERO. This is a deviation from most processors in that you can flash your LED with out effecting the rest of the port with out doing a read/modify/write cycle. This can save a lot of time randomly toggling ports, espescially since you can set or reset as many as you want in a single write. The ARM CORTEX goes all the way to direct hardware pin addressing.
