The Chinese amplifier has "an excellent sense of hearing". So watch what you say because this Chinese amplifier can hear you.
The datasheet for the TDA2030A amplifier IC says that its minimum power supply is 12V but you are feeding it only 9VDC? It has a rectifier diode (only one??) that reduces your 9V to maybe 8V. With a 24VDC supply its output into 8 ohms is 6W. With your 8V supply its output power is almost nothing.
This was a fun project and took less than a day to complete. The case was recycled from an old air ioniser.
The wallwart was from an old broadband route
Iam reluctant to put in more voltage without first putting a better heatsink in place.
The wallwart was from an old broadband router and probably not the cleanest power source for an audio application, but I didn't have HiFi performance in mind with this project. I too have a big box of wallwarts on hand! Higher voltage would not be a problem if desired, but definitely with more heatsinkage and some ventilation holes in the case.
You are wise to be cautious, but in the case of the TDA2030, you have no worries, so long as you don't exceed +-14V or 28V supply lines. The chip has both short circuit and thermal protection and is inherently as tough as old boots. My guitar practice combo has a TDA2030 running 24V with a similar sized heat sink to your bench amp. The power content in music is very low, so the only time the chip may shutdown due to over heating is if you are putting a continuous tone through it but, even so, you will not damage the chip.
In any case, if you are a purist just bolt some aluminum sheet to the existing heat sink- job done. Ventilation holes would be a good move under any circumstances. Assuming the unit sits on feet so the bottom is clear of the work surface, holes in the bottom and top would be best, as heat lost from the heat sink is mainly by convection and, as no doubt you know, convection currents rise, because hot air is less dense (lighter) than cold air
About protection: the circuit is protected from reverse voltage input. The only thing it is not protected against is over voltage (28V). If you did want to protect for overvoltage, a series 1k resistor would not be good, but a series 1A fuse with 24V (say) zener would do the job nicely.
After reading your post I am going to get that amp to go into a pair of second hand nice bookshelf speakers I have just bought with the aim of eliminating the awful audio on our plasma TV (too mean to buy a sound bar).
I am always impressed with re-purposing efforts....
Even in this age of digital TV, the audio output stages and speakers of TV still seem to be regarded as an area where compromises are made particularly with lower priced units. I've never heard one of those sound bars, do they sound good?
I think the OPs reference was with reference to signal input, not DC power, although I can't see exactly where he means.About protection: the circuit is protected from reverse voltage input. The only thing it is not protected against is over voltage (28V). If you did want to protect for overvoltage, a series 1k resistor would not be good, but a series 1A fuse with 24V (say) zener would do the job nicely.
The output stages are fine, it's the speakers that are crap - there's no space in a modern TV for decent speakers or a 'cabinet' for it
Soundbars are fine, if you want a LOT more bass - it's the sub-woofer that really makes the difference. Great for loud music and explosions in action films!.
If you hard wire a pair of small HiFi speakers to the TV they sound amazing.
I expect you're probably right regarding the output stages, though historically some of the TV output stages were horrific.
I'm not familiar with sound bar technology. Why can't it be included in the TV itself?
Totally agree about with this, I have an old Kenwood (TRIO) amplifier and some Celestion Speakers, makes any sound bar I listened to in Currys the other day sound like complete buttocks.
I think you'd have to go back MANY decades to find that, I don't recall any 'horrific' ones - although there were 'horrific speakers' even in some CRT sets.
As you have a stereo module, you could consider bridging to increase your output power.
Oh I misunderstood. I thought you were talking about input power protection. That's what my fuse and Zener were all about.For clarification I've attached a quick diagram.View attachment 96743
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
