Simple Square wave oscillator?
Firnagzen
Could someone reccomend a really simple square wave generator that'll work down to about 1.9v? Or will I have to rely on the good ol' astable multivibrator?
Also, could someone reccomend me a common NPN transistor capable of standing up to 1A with the lowest possible Vce(sat)?
Sorry, I forgot to mention, and was just about to when I called up this topic and you had already replied.
Alright, I need something to replace the Schmitt inverter based oscillator in this circuit: **broken link removed**
That, I think, should be sufficient, right?
Thanks.
Thanks.
If you want to drive an LED with a 'semi-flat' 1.5Vbty, Google for: 'Joule Thief'
How about using a switching regulator to convert your 1.9V supply to a more sensible voltage?
As for low saturation voltage transistors, try any of the following:
ZXTN19020CFF
ZXTN25020CFH
ZTX869
Care to post the solution?
I would use a 74HC00 to make an astable mult-vibrator, the IC is guaranteed to work at 2V but most will probably work down to 1.9V.
