Simple Maths questions? and binary addition/subtraction?
fouadalnoor
Hello guys,
I know this is really silly but I am a little confused about how to do the following operation by hand:
0.25-0.5? or any similar questions:eek:
Also, when it comes to fixed point signed numbers, how do you subtract them?
Say I choose my MSB to be the sign and the 7th bit in an 8 bit number to be 1, while bits 6-0 are the fractional part as shown below:
[SIGN][2^0][2^-1][2^-2][2^-3][2^-4][2^-5][2^-6]
So for example: 01.100000 is 1.5 in decimal.
When aligning the decimal point its easy to add say 1+0.25:
01.000000
+00.010000
=01.010000 = 1.25 in decimal
But how would I do 1-0.25?
Hope you can help!
01000000
-00010000
00110000 = 0.5 + 0.25 = 0.75
rules:
1-0 = 1
1-1=0
0-1 = 1 with a borrow (all zeros upstream become 1 until first 1 hit which becomes 0), if there are no ones upstream, the overflow flag is set (overflow/borrow).
01000000
-00010000
rules:
1-0 = 1
1-1=0
Ah, thanks! Its the 0-1 that is confusing me... but if I had to do 0.25-1 then wouldnt that be: 11010000? but that is not -0.75, it gives me -1.25? is that because there is overflow?
with the sign bit as bit 7, you don't use a '1' for the bit, you use a zero, so a -1 would look like 10111111,
so .25 plus - 1 would look like:
00010000
10111111
and adding them, you'd get:
11001111
which is -.75
for instance, if you don't imply the decimal, a 1 looks like 00000001, a zero 00000000, and minus one 11111111 (the next one below zero), and minus two 11111110, minus three 11111101, etc... it's called sign bit extension for negative numbers
