Simple 4v 2A-3A regulator for battery supply
Scarr
I need a simple (very cost sensitive) voltage regulation, I have a battery pack 4xAA 2900ma and I want to power a GSM862 from this, this is only to send the odd SMS alert, I am controlling the On/Off of GSM with a MIC2505 dual power switch, as the GM862 need 3.4v-4.2v.
So I will have 6v rechargable battaries but need to get this to 4v approx with a cheap mechanism without ideally dumping loads of power.
Any ideas?
Steve
If you want an efficient way then you need a switching regulator. But depending upon you definition of cheap, they probably aren't.
The GM862 is designed to run straight from a Li-Ion battery, like a cell phone battery. There is a battery charger for a Li-Ion battery built into the GM862.
Otherwise, the data sheet for the GE862 shows a typical voltage regulator. If your batteries are NiMh, then they will only be at about 1.2 V most of the time, so the efficiency of a linear regulator set to 4 V will be 80%. Beating that with a switching regulator will be difficult or impossible.
GSM modules are very very hard to power correctly, as they take stupidly large current peaks that start and end very quickly. Your regulator needs to supply 2 A peaks, and if you have a switching regulator that can supply that, it probably won't be very efficient at the 20 mA on standby that the module takes. If you are only sending one text and hour, the vast majority of the battery drain will be from the standby current. That means that the quiescent current is probably the most important feature, so it all points to using a linear regulator.
