halleffector
I'm not even sure where to post this question, and it is quite embarrassing.
I simply want to buy a generic wire for hobbyist projects that has an outer diameter (including insulation) of 1.25 mm, and one with 2.00 mm outer diameter (again including insulation). This will be used for a sensor (Intake Air Temperature) in a car.
However, wire thickness is usually measured in wire gauge, which doesn't seem to count the insulation. I'm also assuming that different wire gauge will typically have different thickness of the insulation, and perhaps different properties for different applications.
I don't even know what to search for, if I want to find something like this on e.g. eBay, namely a wire which has a total diameter of 1.25 mm which comes pre-made with the insulation, what should I search for?
In the past I've simply salvaged wire from various broken devices and used that, but now I need something a bit more specific, and it is the first time I've encountered this trivial problem (and I'm definitely not a professional)!
