setting a config in 16F877A
hi
today is my first time i connect my 877A
to my pickit2 , and now i need some help
on changing the config line the c code
here is the code
#include <system.h>
#pragma CLOCK_FREQ 4000000  // config clock to 4mhz.
// Set configuration fuse.
[COLOR="red"]#pragma DATA _CONFIG, _XT_OSC & _WDT_OFF & _CP_OFF & _PWRTE_OFF[/COLOR]
void main()
   trisb = 0;        //configure port B pins as output
   while( 1 )      //endless loop
     portb.0=1;        // set portb pin0 to high.
     portb.1=0;        // set portb pin1 to low.
     delay_ms( 500 );  // pause 0.5 seconds
     portb=0x02;       // shows hex notation for entering data.
     delay_ms(500);    // you can also write portb=2 in decimal
the red line is the thing i confused on
please help me ! :)
also ,
is 877A have internal clock ?
because i run out of crystal
No internal oscillator.
hi eric
what about if i using resistor for clock
as it shown on the attachment ?
You could do that, change that CONFIG to suit an RC osc.
EDIT:
Its just an output = Freq/4
so i need to set the the set clock to 4040000 , right ?
Unless you are doing something thats time critical, setting it at 4hHz would be ok, or as suggested change the PIC type.
