send data from serial port to microcontroller 16f877a and display to lcd
aldwinsumalabe
please help
data send from pc to pic can loop back and display to pc again. i want to capture the data from microcontronller and assign to a variable and display to lcd. if i send from pc , microcontroller respond that data is receive.
.tnx
 program testlcd1
 'dim msg as string
 'UART1_DATA_READY as byte
       ' Lcd module connections
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
    dim i as byte
  sub procedure display1()   'to display text
  Lcd_Out(1,3,"Serial port ")
  delay_ms(500)
   Lcd_Cmd(_LCD_CLEAR)
  Lcd_Out(1,3,"Good luck kk")
delay_ms(500)
 Lcd_Cmd(_LCD_CLEAR)
end sub
  ' to active library
dim receive as byte
'delimiter as string[10]
 dim Attempts as byte
  dim data_ as byte
 dim  Output as string[50]
 dim txt1 as char[16]
   dim uart_rd as byte
   dim aldw as word
main:
  adcon1=0x02
trisb=%00000000
portb=%00000000
trisa=%00000011
'porta=%00000000
Lcd_init()
Lcd_Cmd(_LCD_CLEAR)
Lcd_Cmd(_LCD_CURSOR_OFF)
  'serial port
  UART1_Init(9600)                     ' Initialize UART module at 9600 bps
  Delay_ms(100)                        ' Wait for UART module to stabilize
  UART1_Write_Text("connected to pc")
 UART1_Write(10)                      ' Line Feed
  UART1_Write(13)                      ' Carriage Return
  while (TRUE)
                         ' Endless loop
    if (UART1_Data_Ready() <> 0) then  ' If data is received,
      uart_rd = UART1_Read()
     UART1_Write(uart_rd)
     receive=UART1_Read()
      'output=word(UART1_Read())
        'UART1_Write_Text(output)
           data_=0x1E
           UART1_Write(data_)
          ' UART1_Write_Text(UART1_Write(data_))
            delay_ms(1000)
          Lcd_Out(2,1,"Message receive")
            Lcd_Out(1,1,output)  'dummy variable Output , i want to display the receive data from pc  to lcd
               delay_ms(4000)
          else
              Lcd_Cmd(_LCD_CLEAR)
                    delay_ms(1000)
          'Lcd_Out(2,3,"Waiting")
                display1()
                      delay_ms(1000)
    'end if
     end if
  wend
end.
