Scrolling vertical messages
Scrolling Vertical messages down
' * Project name:
' vertical_messages_down
' ' ' * Description:
' This code demonstrates scrolling vertical messages down
' on 8x32 dor matrix, 2x74hc154.
' * Test configuration:
' MCU: PIC16F628A
'' Oscillator: HS, 20.000 MHz
' config: PWRITE_ON, WDT_OFF, LVP_OFF, HS
' Ext. Modules: None
' SW: mikroBasic v7.2
' date: March 18th, 2010
' * NOTES:
program vertical_messages_down
const supra as byte[30] = (
$00, $46, $49, $49, $49, $31,' // S
$00, $3F, $40, $40, $40, $3F,' // U
$00, $7F, $09, $09, $09, $06,' // P
$00, $7F, $09, $19, $29, $46,' // R
$00, $7E, $11, $11, $11, $7E)' // A
dim i, x as byte
dim temp_array as byte[32]
dim shift, a, value, column as integer
main:
'Set int Port operations
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
' Calculate the number of columns in the text
column = 30
'Temporary array reset
for i = 0 to 31
temp_array = 0 'Array elements start out 0
next i
while true
'Shift operations
for shift = 0 to 31 'prolong spaces to repeat again
'32 columns of text divided into pieces
for i = 0 to 31
value = i + shift /column
if(value > 0) then
temp_array = 0 ' text input
end if
if(value >= 0) and (value <= column - 1) then
temp_array = supra[value]
end if
if(value > column) then
temp_array = 0
end if
next i
'Scanning process
for a = 0 to 40 'control scrolling speeds...higher number is slowest and lowest number is fastest
for x = 0 to 31 'Temporary array view 32 colums
ClearBit(PORTA, i) 'Clear the Ghost locations ready for starting
portb.i = 0
portb = temp_array[x] << shift 'send data to PortB
porta = x 'select the corresponding column
Next x
nop
nop
next a
next shift
wend
goto start
end.
Youtube:
YouTube - scrolling vertical messages down
scrolling vertical messages up
* Project name:
' vertical_messages_up
' This code demonstrates scrolling vertical messages up
' MCU: PIC16F628A
' * NOTES:
program vertical_messages_up
dim i, x as byte
main:
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
column = 30
for i = 0 to 31
next i
while true
'Shift operations
for i = 0 to 31
if(value > 0) then
end if
end if
temp_array = 0
end if
next i
'Scanning process
portb.i = 0
portb = temp_array[x] >> shift 'send data to PortB
Next x
nop
nop
next a
next shift
wend
goto start
end.
youtube:
YouTube - scrolling vertical messages up 8x32 dot matrix
scrolling vertical messages down from centre to left
* Project name:
' vertical_down_centre_to_left
' This code demonstrates scrolling vertical down from centre to left
' MCU: PIC16F628A
' * NOTES:
program vertical_down_to_left
dim i, x as byte
main:
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
column = 30
for i = 0 to 31
next i
while true
'Shift operations
for shift = 0 to column 'prolong spaces to repeat again
for i = 0 to 31
value = i + shift
if(value > 0) then
end if
end if
temp_array = 0
end if
next i
'Scanning process
for a = 0 to 35 'control scrolling speeds...highuer number is slowest and lowest number is fastest
portb.i = 0
Next x
nop
nop
' delay_us(1000)
next a
next shift
wend
goto start
end.
youtube:
YouTube - scrolling vertical messages down from centre to left 8x32 dot matrix
scrolling vertical messages down from centre to right
[B]scrolling vertical messages down from centre to right[/B]
Project name:
' vertical_down_centre_to_right
' This code demonstrates scrolling vertical messages down from centre to right
' MCU: PIC16F628A
' * NOTES:
program vertical_down_to_right
dim i, x as byte
main:
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
column = 30
for i = 0 to 31
next i
while true
'Shift operations
for i = 0 to 31
value = i - shift
if(value > 0) then
end if
end if
temp_array = 0
end if
next i
'Scanning process
portb.i = 0
Next x
nop
nop
' delay_us(1000)
next a
next shift
wend
goto start
end.
youtube:
YouTube - scrolling vertical messages down from centre to right 8x32 dotmatrix
scrolling vertical messages up from centre to top left
roject name:
' vertical_up_from_centre_to_top_left
' This code demonstrates scrolling vertical messages up from centre to top left
' MCU: PIC16F628A
' * NOTES:
program vertical_up_centre_to_top_left
dim i, x as byte
main:
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
column = 30
for i = 0 to 31
next i
while true
'Shift operations
for i = 0 to 31
value = i + shift
if(value > 0) then
end if
end if
temp_array = 0
end if
next i
'Scanning process
portb.i = 0
Next x
nop
nop
' delay_us(1000)
next a
next shift
wend
goto start
end.
Youyube
YouTube - scrolling vertical messages up from centre to top left 8x32 dot matrix
scrolling messages vertical up from bottom to top right
Project name:
' vertical up from centre to top right
' This code demonstrates scrolling messages vertical up from bottom to top right
' MCU: PIC16F628A
' * NOTES:
program vertical_up_centre_to_top_right
dim i, x as byte
main:
trisb = 0
trisa = 0
portb = 0
porta = 0
cmcon = 7
i = 0
a = 0
x = 0
column = 0
shift = 0
value = 0
start:
column = 30
for i = 0 to 31
next i
while true
'Shift operations
for i = 0 to 31
value = i - shift
if(value > 0) then
end if
end if
temp_array = 0
end if
next i
'Scanning process
portb.i = 0
Next x
nop
nop
' delay_us(1000)
next a
next shift
wend
goto start
end.
youtube:
YouTube - scrolling vertical messages up from centre to top right 8x32 dot matrix
Good job. However, you might want to consider editing your posts and using the code tags so it keeps it's formatting. It is so much easier to read when formatted like this,
Project name:
' MCU: PIC16F628A
' * NOTES:
dim i, x as byte
main:
    trisb = 0
    trisa = 0
    portb = 0
    porta = 0
    cmcon = 7
    i = 0
    a = 0
    x = 0
    column = 0
    shift = 0
    value = 0
start:
    column = 30
    for i = 0 to 31
        temp_array[i] = 0 'Array elements start out 0
    next i
    while true
        'Shift operations
            for i = 0 to 31
                value = i - shift
                if(value > 0) then
                    temp_array[i] = 0 ' text input
                end if
                    temp_array[i] = supra[value]
                end if
                    temp_array[i] = 0
                end if
            next i
            'Scanning process
                    portb.i = 0
                Next x
                nop
                nop
                ' delay_us(1000)
            next a
        next shift
    wend
goto start
end.
You can use code tags by either,
Typing [code] before your code and [/code] after it.
Or,
Go to the advanced page and use the # button.
Highlight the code and click the # on the reply bar.
