Someone Electro said:No
A thyrstors is the same as an SCR(Its just an nother name for it). Its aculy two didoes stacked on eachother.
Styx said:Someone Electro said:No
Well itis actually two BJT's stacked together![]()
Someone Electro said:I know If you conect 2 didoed togeter it wont work.Becose the P of the 1st didoe has to directly toch the N of the 2nd to work right.But has the stucture of 2 didoes an didoe is PN and an SCR is PNPN.
I know you can make one whith 2 transistors but its not gona work good.Its not gona hande huge voltages and curents like an SCR dose.
Styx said:[The two BJT's example will actually work. BUT again you would not use it in practice.
Nigel Goodwin said:Styx said:[The two BJT's example will actually work. BUT again you would not use it in practice.
Yes you would, and it's very common practice!. Obviously NOT for controlling large loads, but for small signal uses - where a latching circuit is required. It also has the advantage that it can have two 'gate' connections, so can be switched from either end.
In fact it's so commonplace that you can buy them in a single encapsulation (obviously made from just four layers of silicon), they are called "silicon-controlled switches" .
If you have a Sony TV under 6-7 years old?, it's almost certain to have a pair of transistors wired as an SCS (silicon-controlled switch), used for latching the protection circuits. That's an obvious current use, but they have been common in TV's since the 1970's.
I believe the original definition was the latter (I'm old enough to remember when they didn't exist). I think the SCR predates the term 'thyristor', because the SCR (as I recall) was the first in the family. The term 'thyristor' was created only after several other devices (triac, diac, etc.) in the family were invented.Some resources define silicon controlled rectifiers and thyristors as synonymous, while others define SCRs as a subset of thyristors.
Yes, i remember, the SCR was first: Silicon Controlled Rectifier.Ron H said:Wikipedia saysI believe the original definition was the latter (I'm old enough to remember when they didn't exist). I think the SCR predates the term 'thyristor', because the SCR (as I recall) was the first in the family. The term 'thyristor' was created only after several other devices (triac, diac, etc.) in the family were invented.Some resources define silicon controlled rectifiers and thyristors as synonymous, while others define SCRs as a subset of thyristors.
Of course, I could be wrong. I was once before.![]()
