Safe to use a SMD zener diode with a higher reverse voltage?
If a circuit originally used a 12 volt SMD zener diode, can I safely use something higher? E.g. a zener diode with a 20 volt reverse breakdown voltage?
It depends entirely on what the zener is doing in the circuit, but it's VERY unlikely - it's also quite likely to cause damage elsewhere.
Consider you have a car with 12 inch wheels, you replace one of them with a 20 inch wheel - how well do you think it will work.
Probably not. It's probably going to have the same effect as replacing a 12V regulator with a 20V. Something is going to blow up.
Deleted post.
Someone doesn't know what a zener diode does...
It's entirely different than other components' -- like capacitors -- voltage ratings.
A zener diode is like a voltage regulator, so specified voltage is of primary importance!
